# Logic
One of the most commonly used standard blocks are conditions blocks.
More about conditions can be viewed at How to use IF and ELSE (opens new window).
# Text
More about that topic can be viewed at Working with Text-Blocks (opens new window).
# CRLF
# Text Replace
Function: Allows to replace something that is defined by the pattern in the origin-text with what is provided in replacement. Note that the pattern can be just a text or also regex expression.
# Colors
More about that topic can be viewed at Using Color-Blocks and HSB-Conversion (opens new window)
# Color Picker
# Random Color
# Create RGB color
# Blend two colors
this could be used for example with a loop that changes the ratio from 0 to 1 to blend the first color into a second
- use that block and connect one of the above blocks into that one to be able to retrieve the HSB value of that block.
# Lists
# Concatenate lists
Function: adds the second list to the first list and returns a new list
# Loops
Even though there a no specialized openHAB blocks provided, loops are used rather often.
Therefore there is a good introduction to loops available which can be viewed at Loops in Blockly (opens new window)
# Functions
A more advanced feature for reusable blockly code is functions.
More about that topic can be viewed at Functions (opens new window) and Parameters (opens new window).
